Clutch drag - MC16
mat grant
Clutch drag - MC16
Mon Oct 10, 2005 3:11 pm » Post: #1 » Download Post
Hi all,
Today while the NSR fairing lowers are off while I try to fix the coolant leak, I thought I'd adjust the clutch, which since I've had it, has had a bite point right near the handlebar and loads of clutch drag once warmed up.
So I adjusted it so the bite point was right near the end (other end) of the lever travel, to the extent it would slip a bit on full acceleration, but the clutch was still dragging.
I hve now set it up properly for bite point and it has quite a bit of drag when the lever is fully pulled to the bar - to the extent that to find neutral coming to a light you have to nudge it into neutral while still rolling a bit.
Has anyone had this problem? Are my clutch plates warped? Any advice appreciated! Plus any tips on how to find a coolant leak(!!!) - it's not the pipe I thought it was.
Cheers, Mat.
mick
Mon Oct 10, 2005 3:27 pm » Post: #2 » Download Post
definatly sounds like warped clutch plates
