oil system
steve101
oil system
Mon Aug 29, 2005 8:58 am » Post: #1 » Download Post
just wondering is it normal for 2 strokes it spit oil out the back of the exhaust because i always have to clean the rear fearings after going for a long ride it dosent spit it out when its ideling i think it dose it higher in the rev range
Mon Aug 29, 2005 9:01 am » Post: #2 » Download Post
We call it 'spooge' and year it's normal. You shouldn't have too much, and if so your oil pump may be set a bit high. Check the main site for setup of the pump.
steve101
Mon Aug 29, 2005 9:11 am » Post: #3 » Download Post
thanks dave i think it might be set to high how much do you think is normal
Mon Aug 29, 2005 10:00 am » Post: #4 » Download Post
A light smoke on startup from cold, then nothing once warm.
At the end of a long ride, you should have no more than a smear round the end of the pipes. Any more than this isn't harmful to the motor, you're just using more oil than needs be.
Wrench.
Wed Aug 31, 2005 1:31 am » Post: #5 » Download Post
Your jetting is too rich at some point.
If your bike is jetted correctly, it will burn all the oil even if the pump is turned up to max. Too rich, and your combustion temps are too low to burn the oil. This also hurts power alot.
Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
steve101
Mon Sep 05, 2005 1:35 am » Post: #6 » Download Post
i get over spray all over the rear of the bike
Steve C
Mon Sep 05, 2005 3:33 am » Post: #7 » Download Post
It's all part of the funnnnnn unnnnn. Razz
Mon Sep 05, 2005 6:36 am » Post: #8 » Download Post
steve101 wrote:i get over spray all over the rear of the bike
Really? How's the power feel? Sounds like you could get more by running a little leaner.
