Base gaskets thickness with o-ring heads..
Enessr
Fri Jan 09, 2026 9:00 am » Post: #1 » Download Post
Morning all,
As title guys, what thickness of base gaskets are required
when fitting straight plug, o-ring cylinder heads?
I can't find any alternatives other than the standard
original Honda versions, except for dmr 0.4mm versions off jauce.com.
Anyone know where to look?
Fri Jan 09, 2026 10:52 am » Post: #2 » Download Post
My understanding is the standard 0.5mm gasket is the default, and the inserts should be already machined for them our-of-the-box. However, the manufacturer/seller should confirm this both with included instructions, and by direct communication.
Point of note though, if the kit has been bought second hand, then there is no guarantee the inserts have not be custom machined, so both the squish and the combustion chamber capacity should be measured.
If you purchased from TYGA (or one of their re-sellers) or VHM, then I'd be shocked if they didn't supply a spec sheet or can't/won't confirm via e-mail. If you bought from a Chinese manufacturer, I strongly recommend the point above. The Chinese copy stuff without the understanding of the application (and often, technology!), and I can't be sure they didn't simply copy a used set of VHMs or similar, that were set for a specific tune or fuel. Their reproduction PGM-III is a classic example, that cannot be delimited with a wire-splice, because they blindly copied a stock unit without understanding how it works.
Enessr
Fri Jan 09, 2026 2:39 pm » Post: #3 » Download Post
Thanks Andy, excellent advice.
I bought a set used, definitely not vhm but definitely not the vhm
price tag either.
Ill measure up and check the squish before fitting.
behu71
Sat Jan 10, 2026 12:21 am » Post: #4 » Download Post
I fitted some VHM heads to my NSR and the squishes were much tighter than VHM specified. Didn't want to play around with base gaskets until I do a full rebuild. Old school trick for you - fax paper makes good gasket material for small squish adjustments.....
Sat Jan 10, 2026 1:52 pm » Post: #5 » Download Post
Always need to be very careful with used heads. Very often, the inserts will be re-machined from standard.
