PGMII VS PGMIII
Jeff SZ
PGMII VS PGMIII
Sun Apr 04, 2004 2:16 pm » Post: #1 » Download Post
Can someone tell me what makes them different ? I know that they are MC18 VS MC21 ! but operation wise would they even work if swapped ?
Sun Apr 04, 2004 3:42 pm » Post: #2 » Download Post
I have a 1989 MC18 R5K (PGM-II) but it doesnt have a GPS like the later MC21 PGM-III set up. I wouldnt of thought it was imposible to run the earlyer PGM-II with the rest of the PGM-III system but might be alot of work for a step backwards?
Sun Apr 04, 2004 6:33 pm » Post: #3 » Download Post
The F3 MC21 kit uses an RS250 PGM-II, but that is slightly different to an MC18 PGM-II.
It would indeed be taking a step backward, fitting an MC18 PGM-II to an MC21, unless of course you PGM-III is dead and you have an MC18 unit and harness to hand!
As Stephen rightly says, the MC18 has no G.P.S. The PGM-III uses this, in conjunction with the T.P.S. and an it's internal RPM sensor, to alter the ignition timing and PJ solenoids according to each input parameter. This makes the system much more tunable, and consequently, the power delivery much smoother.
Jeff SZ
Tue Apr 06, 2004 12:03 am » Post: #4 » Download Post
Thanks for the answers you guy, make complete sense.
