NSR 250 SP w/900 miles won't start - stuck exhaust valves?
Masinari
Sat Jun 13, 2020 5:21 am » Post: #1 » Download Post
Hi guys,
I have a NSR SP Repsol which I bought new in 1996 and ridden regularly (even if little because I love it to be perfect). The bike used to start and run perfectly. I always drained the tank and refilled it with fresh fuel, in the past, but this time I had travel abroad for work and the bike sat without running for 4 years and did not start.
When the key is inserted, I didn't hear the usual "valves cycling open and close". The red warning light on the dash turned on. The bike won't start at all.
1. Are the exhaust valve easy to clean/accessible from the outside with solvent without taking the cylinder barrel off? Is it worth tapping the area to unstick them? 2. If the servos get stuck and the warning light is on, does the ECU cut off the spark (and that is possibly why the bike won't start)?
3. Do you know any specialist/repair shops in Connecticut capable to work with me to fix it?
Looking forward to your advice and recommended tech to work on my baby. Many thanks guys. Much appreciated:) will attach a photo so you can see the bike.
ADMIN: Moved to NSR250 Discussion.
Max
Sat Jun 13, 2020 6:51 am » Post: #2 » Download Post
The RC valves are accessible without taking the barrels off and from the outside, it is an easy enough job to do for the novice mechanic if you go carefully and follow the manual or guidance.
There are guides written on here if you use the search function and term "RC Valve Removal".
What mileage do the valves have on them at the moment?
You know your bike best but is there a chance that this is just a case of a non-optimal battery? NSR's like new good quality batteries full of power to cycle the RC servo motor prior to starting.
Which warning light is showing?
And my final question, please let me buy your bike! 🙏 ROTFLMAO
Sat Jun 13, 2020 11:47 am » Post: #3 » Download Post
Wow a 1 owner since new Repsol SP. Now that id like to see
