Alternate trunk lock for MC21?
scottvor
    Send private message View user's profile Send e-mail AIM Address
Thu Jul 09, 2020 5:04 pm » Post: #1 » Download Post
Bike had separate key for ignition and trunk lock. Managed to lose the trunk lock key. Anything else fit? Anyone try the cheap locksets from fleabay?
Cure
Thu Jul 09, 2020 6:33 pm » Post: #2 » Download Post
Hi Scott if you can get the box open remove locking mech and with a small flat screwdriver force the stainless steel lip that ticks under open enough to remove tumbler put your ign key in and file or belt sand tumblers till they are flat the lock will them work of that key with a small hammer on a hard cardboard,ply surface hammer the lip back down
I’ve done it a few times and it sorts it 👍
take your time good luck
jonmac
mreebikes
Alternative lock set
Sun Jul 12, 2020 10:16 pm » Post: #3 » Download Post
I bought a lock set from fleabay. Cheap is one for word for it... However, after mod'ing the trunk lock so it actually latched and swapping the steering lock part on to the new set it actually works OK.
