What determines where the lock nut should be on the damper rod on the front forks. Fitting new seals and giving everything a once over and one lock nut is to the bottom of the thread and the adjuster down to it one is about 8mm from the bottom. Not sure what this affects but imagine they should both be the same but where is that / how is that set?
Thanks
Cam
