Question about MC28 Valve issues
bandicoot58
Wed Mar 29, 2017 1:16 am » Post: #1 » Download Post
Hi guys,
I was wondering if someone can help me out, seems to be having problems with this part:
06140-KV3-980
On mine, the bolt had striped and I cannot take off the bolt from the rod.
I was wondering also if you have any ideas/ resource where to get the replacement, I saw some on YAJ, but mostly they are for MC-21 and I am not sure if it will fit MC-28.
Any ideas / help is greatly appreciated.
Thanks.
Wed Mar 29, 2017 7:13 am » Post: #2 » Download Post
Just checking you know the nut is undone clockwise?
From my searches all new pv shafts are discontinued.Auction site are probably the only option
NS Factory do have a request for reproduction on their site
ian_gt
Wed Mar 29, 2017 11:38 am » Post: #3 » Download Post
As RobH says, be aware it's a left-hand thread. I found this out the hard way : )
Are you sure you can't find any way of gripping it, or perhaps get someone with a welder to tack a bit of bar on it? Chances are the shaft is ok, then you just need a new nut. I think they're M6x1mm, left-hand, but best check.
Wed Mar 29, 2017 5:51 pm » Post: #4 » Download Post
Also, 21 and 28, should be the same.
bandicoot58
Wed Mar 29, 2017 7:37 pm » Post: #5 » Download Post
@Lesviffer750
Thanks for confirming!
@all thanks for the help.
KL2585
Fri Mar 31, 2017 5:04 am » Post: #6 » Download Post
Anyone know how to take out the rod?
Fri Mar 31, 2017 5:59 am » Post: #7 » Download Post
It's only the oil seal that holds it in. There is an E clip that locates the PV shaft, but that only sits behind the seal. I used a vice with fibre jaw plates, clamped the PV shaft and pulled the shaft out
ian_gt
Fri Mar 31, 2017 1:04 pm » Post: #8 » Download Post
Tyga make an RC valve puller. I can't remember how I did mine previously, I think like RobH I used fibre jaws in the vice and tapped it out patiently.
