what is the bottle on the reed cage for?
sparky
Fri Jun 01, 2012 12:58 am » Post: #1 » Download Post
I noticed on my mc21 that it is missing the pastic bottle that is attached to the reed cage. (16310-KV3-000 CHAMBA COMP. in let )
what is the purpose of that bottle?
Hobbit210
Fri Jun 01, 2012 6:27 am » Post: #2 » Download Post
I believe that it's main function is to help equalize the pressures in the carb inlets. There is more to this, as someone will tell you I feel sure, BUT one thing is for sure...you must not run the bike without it...if it will run at all.
Mike
sparky
Fri Jun 01, 2012 6:35 am » Post: #3 » Download Post
that could explain why it runs like sh*t at the moment.
nxrsr20
Fri Jun 01, 2012 9:51 am » Post: #4 » Download Post
you want me to add them to the shipping quote for you mate? Smile
t3racing
1990 Honda NSR300 MC21 SP
Fri Jun 01, 2012 11:11 am » Post: #5 » Download Post
Well mine runs without them, they have been capped and filled in so the intake is nice and smooth. Smile
If your bike is not running very well then I doubt its down to the boost bottle not being present
MC21 300
Aprilia RS250 track bike
Chester362
Fri Jun 01, 2012 11:52 am » Post: #6 » Download Post
t3racing wrote:Well mine runs without them, they have been capped and filled in so the intake is nice and smooth. Smile
Unless his insulators haven't been plugged?
If someone just took the chambers off and left the holes open it would run like sh!te.
Like you Mark, I would guess they have been blanked and the bike is running rough due to some other issue.
t3racing
Fri Jun 01, 2012 11:59 am » Post: #7 » Download Post
That's true, I just assumed the holes had been plugged and I should know never assume anything.....
MC21 300
pbekkerh
Fri Jun 01, 2012 12:22 pm » Post: #8 » Download Post
"The road to hell is paved with assumptions" Wink
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
bandit_7
Fri Jun 01, 2012 12:31 pm » Post: #9 » Download Post
Hobbit210 wrote:I believe that it's main function is to help equalize the pressures in the carb inlets. There is more to this, as someone will tell you I feel sure, BUT one thing is for sure...you must not run the bike without it...if it will run at all.
Mike
I'm not sure that's an accurate statement being that HRC manufactured plugs for those holes. The only difference I noticed was a slightly rougher mid range and smoother top end when I removed the bottles.
Fri Jun 01, 2012 12:55 pm » Post: #10 » Download Post
http://www.totallyamaha.com/snowmobiles/aaTECH/BoostBottle/boost_bottle_theory.htm
I guess if you're racing the boost bottle has little effect, but does on the road
sparky
Sat Jun 02, 2012 12:07 am » Post: #11 » Download Post
Yes the holes were plugged.
today i swapped the reed cage from the spare motor with with boost bottles onto the bike. it helped a bit but not too noticable.
i played around with the bike and for some reason, it only seems to run semi smooth is when i run it without an air filter.
Sat Jun 02, 2012 1:24 am » Post: #12 » Download Post
We've had varying degrees of success removing the intake chamber, depending on the state of tune, and the setup. My current setup performs best with the bottle, but previously we were running it without.
bandit_7
Sat Jun 02, 2012 6:00 am » Post: #13 » Download Post
Personally I'd say my bike would be better off with the bottles on too considering it's only used on the road. It's just that after having the old girl off the road for about 2 years I'm just happy it's running again and can't be bothered pulling the carbs off again.
nxrsr20
Sat Jun 02, 2012 8:56 pm » Post: #14 » Download Post
sparky wrote:Yes the holes were plugged.
Have you checked your idle circuit is clean and carbs set to factory settings?
