A few dry clutch bits wanted
Sun Oct 23, 2011 1:51 pm » Post: #1 » Download Post
I realise I'll probably have to buy these new but I'll ask here first, I need;
The spacer that goes between the bearings on the main shaft collar (28238-kv3-840, part 16)
The collar that rides on the main shaft that the above spacer and the two bearings run on (28242-kv3-840, part 17)
The clutch lifter and it's pushrod (22352-kv3-780 and 22851-kv3-780, parts 12 and 14) and if someone has one, the little bearing (96211-08000 part 33) though it is in stock at Honda UK and only 6p!
Thanks!
