wanted list of parts below
nigel hunt
Tue May 24, 2011 9:30 am » Post: #1 » Download Post
radiator although i think a member has me sorted
2 piston kits
front barrel and head or maybe a matching pair
set plugs which are best ?
gearbox oil which is best ?
ignition barrel as 1 on bike is liable to turn off over a bump any other bikes fit nc30 etc
air filter
braided brake lines wheres best to buy these ?
brake pads whats best type ?
wheel bearings
headstock bearings
fork seals
fork dust seals
chain and sprockets standard gearing or change it just for roading riding ?
headlight
clear screen
pillion seat or cowl infill
just a wee wish list if anyone has any of the above or info where to buy at decent prices id be very gratefull/
pvan340
Re: wanted list of parts below
Tue May 24, 2011 9:56 am » Post: #2 » Download Post
nigel hunt wrote:radiator although i think a member has me sorted
2 piston kits
Tyga
Yahoo auctions japan
auctions.yahoo.co.jp
NGK Br9ecm
Motul semi-synthetic is what I use, I have a wet clutch mc18
Check your local bike store for an aftermarket one, failing that
air filter
gavin at jap4 may have some
HEL - check the supporting vendors
I like EBC - wemoto stocks all this stuff
wheel bearings
headstock bearings
fork seals
fork dust seals
Tyga
Wemoto
headlight
clear screen
Hope this helps. The search fuction works well, as does google. Message Moriwaki Man in regards to parts from japan.
Have fun!
nxrsr20
Tue May 24, 2011 10:03 am » Post: #3 » Download Post
posting in the classifieds section will also prevent you from ticking off the moderators Smile
Canuck13
Tue May 24, 2011 10:19 am » Post: #4 » Download Post
For what model? I have a bunch of surplus 18 bits.
nigel hunt
mc18
Tue May 24, 2011 12:36 pm » Post: #5 » Download Post
thats the next question as i cant make out what model it is , how do i tell what model mc18 it is ?
Chester362
Tue May 24, 2011 4:38 pm » Post: #6 » Download Post
Dan's got some pistons and rings on his site. Cheaper than Honda dealers.
http://www.geckomotorcycles.co.uk/index.php?act=viewCat&catId=25
Gavin at Jap4 sells Tyga stuff in the UK.
http://www.jap4performance.com/
I use David Silver for Honda parts too.
http://www.davidsilverspares.co.uk/
As mentioned earlier, Andy sells Hel brake lines at a good rate from this site.
http://nsr-world.com/marketplace/
Canuck13
Re: mc18
Wed May 25, 2011 5:31 am » Post: #7 » Download Post
nigel hunt wrote:thats the next question as i cant make out what model it is , how do i tell what model mc18 it is ?
Take a look at the model history page on the website. My way of doing an easy approx way is the later 18 models have a high level pipe with a stainless section between the expansion chamber and the cans, tho this doesn't work if the exhausts have been changed out. Next way is looking at the pgm, PGM I for early and PGM II for later. Others will undoubtedly tell you the correct way Smile
nigel hunt
Wed May 25, 2011 8:41 am » Post: #8 » Download Post
the pipes are a lower type sitting at same level to each other the colour scheme was blue and white and the ecu box just says pgm , would that be correct , another thing is as the front barrel and head was missing the rear barrel and head has what appears to be thge letter F on the left hand side down at base of barrel , ive beeen told that there are a,b,c barrels and pistons dont always match up , can anyone help with this as i have no manual and my subscription on this site hasnt activated as yet , thanks in advance .
