tyga gp pipes
planb100
tyga gp pipes
Sun Oct 20, 2013 12:45 am » Post: #1 » Download Post
Having an issue with the right side pipe aligning with the screw hole has anyone had this problem before or am I gonna have to dent the pipes up and do some welding? Let mr know how you guys passed this problem ill add picture in a bit
1992 Honda NSR MC 21 SE
planb100
Sun Oct 20, 2013 3:22 am » Post: #2 » Download Post
Picture of the issue
scottvor
    Send private message View user's profile Send e-mail AIM Address
Sun Oct 20, 2013 8:06 am » Post: #3 » Download Post
When fitting both Jha and Tyga non-GP pipes to my MC28, I had to make a small bracket to drop mounting point about an inch. Of course this did require modifying (hacking!) at my non-stock bodywork.
Sun Oct 20, 2013 2:19 pm » Post: #4 » Download Post
We've found it's usually down to poor alignment at the manifolds, particularly with the TYGA chambers, that can be a bit fussy.
The [TYGA] pipes are all built on the same jig, so if your frame is straight, there is no reason why they should fit any worse than any other set of TYGA pipes... which usually fit right up without any problems.
Jha, HARC Pro, Ethos, DogFight, and everything else should fit just the same too. I've yet to see a set of pipes that didn't fit properly to a straight frame in 20 years!
Chester362
Sun Oct 20, 2013 4:13 pm » Post: #5 » Download Post
Are you still using the standard footrests and rearsets?
I seem to remember something about needing to use aftermarket, higher rearsets with the Tyga chambers.
I think they state on their website that the exhausts won't fit with standard rearsets.
planb100
Sun Oct 20, 2013 9:28 pm » Post: #6 » Download Post
The bike is all around in good shape been well taken care of no damage at all to the frame don't understand what the problem could be otherotherwise, the left side went in perfectly just the right side won't budge
planb100
Sun Oct 20, 2013 9:59 pm » Post: #7 » Download Post
and yes stock foot rests are being and also using the special manifolds tyga sells for the pipes
simono
Sun Oct 20, 2013 10:48 pm » Post: #8 » Download Post
Had the same with Sambas on the RS .. a good beating is in order Very Happy
Neal
Mon Oct 21, 2013 11:30 am » Post: #9 » Download Post
Loosen the front special flanges and then screw in the bolt and tighten the flanges afterwards .
NSR300
Chester362
Mon Oct 21, 2013 12:37 pm » Post: #10 » Download Post
I was on the Tyga website yesterday. It looks like I was talking out of my bottom earlier!
For the side by side exhausts they state they will fit with standard rearsets.
Not sure on the GP exhausts though.
Are you using the standard manifold exhaust gasket between the flange and cylinder, or have you fitted the flanges direct, without the gaskets?
Those spring type gaskets are about 8mm thick, if I remember correctly.
Might give you the little bit of play that you need.
planb100
Mon Oct 21, 2013 7:34 pm » Post: #11 » Download Post
I was told about an o-ring o_O am I suppose to be using a honda oem o-ring or is it something I forgot order along with the parts on the tyga site I am sure I bought everyting on theee
Sun Oct 27, 2013 11:15 am » Post: #12 » Download Post
Maybe they're MC28 pipes, not MC21?
ericandchi
Mon Oct 28, 2013 12:22 pm » Post: #13 » Download Post
I had the exact same problem but a part of it was my own doing because i included a high temp o ring in the collar. A few seconds of just the right amount of sanding to the collar on the belt sander made for a perfect fit.
