Dog Fight Expansion Chambers
cangus
Mon May 20, 2013 11:30 am » Post: #1 » Download Post
Does anyone know if Dog Fight expansion chambers are made to be used without the crush washers? They have o-rings and seem to fit better without crush washers?
Thanks.
MC21R9N track
MC18R2J track
CBR954
CR250
Mon May 20, 2013 2:06 pm » Post: #2 » Download Post
mine just use the o rings in the exhaust chamber and they never blew or leaked from where they joined
cgallant
2001 Honda RS250
Mon May 20, 2013 2:45 pm » Post: #3 » Download Post
If the dog Fight exhaust uses a manifold that the actual chambers slip onto (and that part has an O-ring where the manifold/chamber slip together) then you want to have some form of seal between the manifold and the cylinder/exhaust port. The stock cylinders do not have a smooth surface for matting a manifold to, so you need either the big cooper crush washer/fitting or some other form of seal (never seen any other seal system for this).
Without a seal, you will get leaks from that attachment point.
Mon May 20, 2013 3:35 pm » Post: #4 » Download Post
The engine has to run for them to leak, Si!
Mon May 20, 2013 4:21 pm » Post: #5 » Download Post
i should have seen that coming Laughing
under the belt
Mon May 20, 2013 4:53 pm » Post: #6 » Download Post
Hi Si ,you say you should have seen that coming,i thought the comments were fair and then that out of the blue,if it was a boxing match he would have been disqualified,
but i must say it did make me chuckle,
jonmac,
Mon May 20, 2013 8:34 pm » Post: #7 » Download Post
I'd never swing after the bell! It's just not British! Laughing
Tue May 21, 2013 12:08 pm » Post: #8 » Download Post
Laughing to be fair to andy,that was a tame comment to what i usually get,bloody cyber bullies ROTFLMAO
cangus
Tue May 21, 2013 12:26 pm » Post: #9 » Download Post
thanks guys. always a treat.
MC21R9N track
MC18R2J track
CBR954
CR250
toneless
Re: Dog Fight Expansion Chambers
Sat May 25, 2013 7:43 pm » Post: #10 » Download Post
cangus wrote:They have o-rings and seem to fit better without crush washers?
If there is not a good fit while using the copper washers, do not overtighten the exhaust nuts as the exhaust flange will bend and eventually leak.
2t-racelab.com
