Any difference between MC21 & NC30 brake calipers?
Chester362
Tue Jun 26, 2012 11:30 pm » Post: #1 » Download Post
Does anyone know if the front brake calipers are the same for the NC30 & the MC21?
Now I've fitted the new 1991 RS front forks I'm finding the calipers foul against the discs.
Andy, When you had these forks fitted, did you use the RS calipers?
Thanks in advance.
Wed Jun 27, 2012 12:13 am » Post: #2 » Download Post
NC30 and MC21 calipers are different, although outwardly look the same. You cannot use MC18/MC21 calipers with 296mm disks.
You will need to either use NC30 or NF5 calipers.
Neal
Wed Jun 27, 2012 7:53 am » Post: #3 » Download Post
Get yourself the brembo callipers but you will need the adaptor plates . You can feel the difference . You can modify the 21 callipers to fit too . Heath Robinson did it .
Wed Jun 27, 2012 8:51 am » Post: #4 » Download Post
Iv'e fitted brembos to my 21 Roy, and the difference is very noticeable, well worth the effort if your racing i would have thought, im not, but i had em any way.
Chester362
Wed Jun 27, 2012 5:16 pm » Post: #5 » Download Post
Thanks for your replies.
Much appreciated.
Thu Jun 28, 2012 12:56 am » Post: #6 » Download Post
I'm using NF5 calipers, HEL lines, and a CBR1000RR radial master cylinder, and the brakes are incredible. HRC cast iron discs too though, with awesome FCM pads.
I don't think you'll have any issues with NC30 calipers, and of course no problem at all with NF5 items (if you have some or can find them - plus they have trick little Q/R pins!). The biggest difference I found was replacing the master cylinder with a modern radial one.
All those parts are simple bolt-ons too. No adaptor brackets, which I think personally look a bit "clumpy".
Sat Jun 30, 2012 3:22 am » Post: #7 » Download Post
Andy wrote:NC30 and MC21 calipers are different, although outwardly look the same. You cannot use MC18/MC21 calipers with 296mm disks.
I beg to differ.
You know me Andy, there is no 'cannot'.
They may be different but they can be used. It just depends on what you're doing.
Sat Jun 30, 2012 4:55 am » Post: #8 » Download Post
OK, unmodified NSR250 calipers cannot be used. I was alluding to standard bolt-on parts.
For most, sourcing a set of NC30 calipers is ultimately easier, cheaper, and more viable than buying the special socket to strip NSR calipers, stripping them, machining them, finding replacement seals, and then rebuilding them.
Sat Jun 30, 2012 8:05 am » Post: #9 » Download Post
We can discuss this over algebra and operands!
Lane
Mon Jul 02, 2012 3:12 am » Post: #10 » Download Post
What "special tool" is required to strip them?
Chester362
Mon Jul 02, 2012 12:01 pm » Post: #11 » Download Post
Lane wrote:What "special tool" is required to strip them?
Just the special socket.
The caliper bolt heads are the 'star' or 'torx' type.
ypm25
Thu Jun 05, 2014 7:33 am » Post: #12 » Download Post
Is the much difference between NC30 and NF5 Calliper forks and disks?
DUX
Banned
calipers
Thu Jun 05, 2014 9:41 am » Post: #13 » Download Post
The "Special Socket" is mentioned in the manual as Torx (female) E12, mine cost £4-00 from King Dick.
I am currently rebuilding a standard set of calipers that have been stood a long time also using Honda seals.
Fri Jun 06, 2014 10:36 pm » Post: #14 » Download Post
A huge difference. It's heyday HRC vs. mass production.
Outwardly, little difference, except for the compression dampening adjusters on the [late] NF5 fork bottoms, and the NF5 calipers having the Q/R pad pins. The operation and quality of the internals however, are fit for GP.
Even I noticed the difference going from NSR forks to NF5 forks, and I'm neither fast nor talented.
