Cylinder head studs
andyo
Cylinder head studs
Wed Mar 28, 2012 6:51 am » Post: #1 » Download Post
Hi, Can someone please tell me the torque setting for the cylinder head studs and if loctite is used? Thanks a lot.
NSR-lizard
Wed Mar 28, 2012 9:13 am » Post: #2 » Download Post
The studs are just wound in with common sense. The workshop manual doesn't give a torque rating for the studs, only the nuts and bolts.
As a Titanium member you can read just about all of the service manual online!
Don't use Loctite! The barrels can be weak in that area in the first place, and can easily fracture if a stud it forced either in or out. Make sure the threads (male and female) are very clean, put a drop of light oil on them, do them up hand tight, then give them about 1/8 of a turn. They don't need any more.
Take even more care with the smaller MC16/MC18 studs, as there's even less "meat" securing them.
Vampire?
andyo
Wed Mar 28, 2012 2:49 pm » Post: #3 » Download Post
cheers for the info lizard, i had looked through the manual but didn't find any details on fitting studs i guess because its not a normal procedure. Once explained yes it makes perfect sense so cheers.
