Maybe I don't have a 10 or 11, as it says '(NOK)' for 11, whatever that means, and only has 10 it listed for certain models. I cannot find part number 10 on my bike so maybe this resides up inside the pump and I'd see it if I removed the drive shaft?
Anyhow, my bike is an SE with a wet clutch engine, so I'm not sure if it is even an MC21 motor, so things may differ...
All I'm trying to find out is where this 8 mm thrust washer goes in relation to everything else, and make sure everything else (the o-rings) are all there as they should be.
