Compression Tester
Hobbit210
Compression Tester
Tue Nov 15, 2011 6:25 pm » Post: #1 » Download Post
Can anyone advice me where might be the best place to get a compression tester. I used to have one when I worked on my own cars but for the life of me I can't find it now.
Mike
Tue Nov 15, 2011 6:45 pm » Post: #2 » Download Post
A Gunson compression tester in Halfords is about £25.
I've seen Draper ones online (places like Machine Mart etc.) for about £15~20.
Hobbit210
Tue Nov 15, 2011 7:59 pm » Post: #3 » Download Post
Halfroids for me tomorrow then.
Thanks
Mike
toneless
Tue Nov 15, 2011 8:36 pm » Post: #4 » Download Post
A little bit on the high side but you can't go wrong with this kit by Accu products.
2t-racelab.com
Hobbit210
Tue Nov 15, 2011 10:52 pm » Post: #5 » Download Post
2Tracelab wrote:A little bit on the high side but you can't go wrong with this kit by Accu products.
Very nice bit of kit but not really what I'm after at the moment.
Mike
Tue Nov 15, 2011 10:54 pm » Post: #6 » Download Post
Thumb over the plug hole method not good enough?
Hobbit210
Tue Nov 15, 2011 11:07 pm » Post: #7 » Download Post
StephenRC45 wrote:Thumb over the plug hole method not good enough?
Not got long enough arms Wink Wink
Mod edit: No eBay links please
FY
Mike
toneless
Tue Nov 15, 2011 11:09 pm » Post: #8 » Download Post
I've been a bit hasty I suppose. Embarassed
2t-racelab.com
toneless
Tue Nov 15, 2011 11:12 pm » Post: #9 » Download Post
Hobbit210 wrote:How about this for value...
I would at least expect a wooden box at this price. Laughing
2t-racelab.com
Tue Nov 15, 2011 11:13 pm » Post: #10 » Download Post
Make sure you buy one that can get into the top cylinder. The frame is in the way for some.
Wed Nov 16, 2011 3:17 am » Post: #11 » Download Post
Quite simple and cheap to make.
I use one of those same pumps as the accu-products uses. Can get them from the medical store for peanuts. Made a plug for the insulator out of aluminium, but another way to do it is to use an old insulator and just fill up the bit where the carb plugs in with epoxy steel, let it set and pop it out. A bit of wax on the insulator first will ensure it doesn't glue itself in there. Then you have a perfect shape part. Drill and tap this to fit the gauge and pump etc.
To block the exhaust I roughly sawed a plate of 10mm aluminium, drilled a couple of holes and use a big fat o-ring (from the plumbing department) to seal it.
Screw in a spark plug and you're ready to rock.
Just make sure you get a reasonably low pressure gauge. I see the accu-product gauge reads 15psi, which is perfect so that you can easily see any drop in pressure.
Wed Nov 16, 2011 7:49 am » Post: #12 » Download Post
There go Mike... everything you didn't want to know about leak down testers! Laughing
Or did I mis-read your post asking about a compression tester?! Confused
Hobbit210
Wed Nov 16, 2011 8:04 am » Post: #13 » Download Post
Well I've certainly learnt a lot today .. heh heh.
Many thanks folks anyway.
Mike
Wed Nov 16, 2011 9:51 am » Post: #14 » Download Post
I blame Andy. The last sms he sent me this morning threw me off track.
