My PGM3 no spark in plugs
eddyleung
    Send private message View user's profile ICQ Number
Sat May 14, 2005 5:36 am » Post: #1 » Download Post
already check all wire for ignition, but it are no problem....
what the problem you think...
pls help me
thank you...
nsrmonkey
Sat May 14, 2005 7:59 am » Post: #2 » Download Post
have you checked all of your earths?
what mods have you done to the bike?
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
eddyleung
Sat May 14, 2005 11:51 am » Post: #3 » Download Post
i already checked all the earth
and i changed new plugs for the bike
but still no working
nsrmonkey
Sat May 14, 2005 12:10 pm » Post: #4 » Download Post
what modifications have you done?
has it been running?
we need a bit more info from you Very Happy
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
eddyleung
Sat May 14, 2005 1:50 pm » Post: #5 » Download Post
no modification in my pgm3 se....
Mon May 16, 2005 3:13 pm » Post: #6 » Download Post
This could be tricky!
How have you checked the wires?
Have you checked that there is 12v to the coils?
Have you checked all the connectors are firmly pushed together, and that there is no corrosion on the pins?
Have you replaced the spark plugs?
Have you access to another NSR so you can swap out the PGM to check it is working?
Are you sure there is no spark and it's not something else causing the problem?
Have you checked the KILL switch is set to RUN?
Let us know more and we'll try to help.
eddyleung
Tue May 17, 2005 6:27 am » Post: #7 » Download Post
i checked cables from computer to spark plug coil(colour: Bu/Gr, Bk/Bu, Bk/Y) which is no any damage...
and i changed 2 new plugs (NGK B8ES)
KILL switch is already set to RUN....
one day i was driving, suddenly the engine stop.....
then i can'r start the engine any more..
finality, i discove that the plugs are no spark
Tue May 17, 2005 6:49 am » Post: #8 » Download Post
Right, but have you checked for voltage at the coils? This will tell us if the coils or the PGM is likely to be faulty.
eddyleung
Tue May 17, 2005 7:28 am » Post: #9 » Download Post
how can i check it??
Thank you
Tue May 17, 2005 8:55 am » Post: #10 » Download Post
Ah, now we're getting somewhere!
Do you have a voltmeter?
eddyleung
Tue May 17, 2005 9:58 am » Post: #11 » Download Post
i got voltmeter
jamiekellard
Same Problem
Thu May 19, 2005 7:04 pm » Post: #12 » Download Post
I had a similar problem a few years back with my nsr 250 mc21.
One day I was riding my bike and the next nothing. I replaced the pgm box and I was back running again. Then a month later it happened again. To cut a long story short there was a crack in the coil that was hidden underneath the rubber strap that supports the coil. My guess was the coil was causing a short and feeding back to the PGM. I had a friend that is very clever with electronics, so we tool apart my broken pgm and discovered a burnt out component that help charges the coils. The bad news was that they fill the pgm circuits with this wax plastic stuff that is a nightmare to get out but we managed to replace the burnt out commpoents by soldering the new component to the legs of the faulty one. Plugged it backing and fantastic it worked.
Jamie
eddyleung
Fri May 20, 2005 4:21 am » Post: #13 » Download Post
thank you Jamie..
i got a question.....
where is the coil which you said that???
jamiekellard
Fri May 20, 2005 6:30 am » Post: #14 » Download Post
Well its been along time since it happen but i'm sure it was the front side cylinder coil that was damage.. If you allready have your fairing off then pull the HT leed of the spark plug and follow the lead back to the coil. They are very short leeds normally, so it wont be that hard. Once you have found the coil, inspect under the ruber strap that supports the coil onto its frame bracket.
Jamie
eddyleung
Fri May 20, 2005 2:23 pm » Post: #15 » Download Post
your mean that i should be changed the bottom coil?
