mc18/21 42 tooth rear sprocket
2Smoke
1987 Honda NSR250 MC16
Tue May 04, 2010 8:32 pm » Post: #1 » Download Post
anyone got a 42 tooth sprocket for an mc18/21 to sell?
Ta
Paul
Neal
Wed May 05, 2010 5:23 pm » Post: #2 » Download Post
Hi Paul ,remember that the 18 sprockets are different to the 21's , the mounting holes are a different size .I am sure that i have a 18 42 rear sprocket , can confirm on the weekend .
Harold
Mc18 rear sprocket.
Wed May 05, 2010 5:39 pm » Post: #3 » Download Post
Hi there.
I don't think there is a 42 tooth rear sprocket for the MC21 or it is
just not very common. It is very easy to convert the MC18's 42 tooth
to fit the 21. I made it fit on my bike and it is working well. You just need
to make the holes for the sprocket carrier bigger. And then just need to
press those 5 little hexagon spacers that goes into the rubber mounts
into the new sprocket. The rest is easy.
Neal
Wed May 05, 2010 8:53 pm » Post: #4 » Download Post
you can get any size , if you need them , you make a plan . I have from 34 to 53 , and i use them all
2Smoke
Wed May 05, 2010 9:06 pm » Post: #5 » Download Post
Thanks yeah I had to modify the one I've got fitted..
I'll probably have to give renthal a shout to make some up, bit of an expense but then I need them teeth! Laughing
Wed May 05, 2010 9:21 pm » Post: #6 » Download Post
Not wanting to turn into a discussion. Rental do one sprocket type that fit all MC18's and MC21's up to 42t.
2Smoke
Tue May 11, 2010 8:53 pm » Post: #7 » Download Post
Bugger its a 43 tooth I need..
Or a 13 tooth front..
For an mc21 wheel
Anyone know any suppliers or have a second hand one to sell? Only need it for tonfanau as 14/42 works good at anglesey..
