some one help me pleaseeee
ac1507
    Send private message View user's profile MSN Messenger AIM Address
Wed Aug 19, 2009 10:09 pm » Post: #1 » Download Post
i have an MC11
and i have cleaned the carburator
but it still starts slow at 1st gear at the begining then it lightes up like a rocket
and some times it dosent start i have to wait like an hour or some one has to push me Crying or Very sad
3 stroke
from one MC11 to another
Thu Aug 20, 2009 7:55 pm » Post: #2 » Download Post
A MC11 also owns me.Mine at 13,000 kms. displays some of your operating symptoms.Mine needs pistons and rings to bring the compression back up to where it will cold start and operate properly.Check your compression.It can be quite low on a 2 stroke,maybe 7 to 1 at cranking speed and they will still run alright.Also on my MC11 after long term storage it developed a bad wireing harness ground.It is located just foreward of the battery,remove the bolt and make all surfaces shiney.On mine the alloy chassis side was dull grey, alluminum oxide is non conductive.With out electric start bad chassis ground can sneak up on you because there is no real high amp draw to reveal it.Back to the pistons ,they are hard to find so I am trying to fit 86 kawasaki KX125 pistons now if I can just find the gaskets all will be good.Stay posted and good luck...Lee
RichG
Thu Aug 20, 2009 8:04 pm » Post: #3 » Download Post
Starting problems could also be a faulty crank seal. My MC21 crank seal had gone, when I got the engine running it was very poor / bogging down at low RPM in first gear. Search on the discussion forum for crankcase pressure testing.
Rich
bushman
Fri Aug 21, 2009 8:09 am » Post: #4 » Download Post
What condition is the battery in?
