Oil Pump setup?
2Smoke
1987 Honda NSR250 MC16
Oil Pump setup?
Wed Mar 25, 2009 2:52 pm » Post: #1 » Download Post
Just converting back to oil injection on the '16, and setting the pump up I have hit a bit of a snag. In the workshop it states that the mark on the oil pump pulley should line up with the triangle on the body, but on mine its gone way past the mark by the time it gets to full throttle, even with the cable set to the slackest. Any ideas?
Paul
ricey3
2006 Honda crf450 r
Wed Mar 25, 2009 4:39 pm » Post: #2 » Download Post
you must be reading it wrong, it dont go much past that, have you had a look at the diagram in the worksop section of the main forum
Max szeged
Wed Mar 25, 2009 10:13 pm » Post: #3 » Download Post
Paul you are using mc18 carbs right? i think that might be the difference.
feel the wind
2Smoke
Wed Mar 25, 2009 11:59 pm » Post: #4 » Download Post
Yes of course, I'll av a look at the pulley differences on the carbs tomorrow..
Ta Max
CircuitR
Thu Mar 26, 2009 5:24 am » Post: #5 » Download Post
This just made me check mine as I am running the same setup. I thought the mark above the stop was the index mark not the the mark at the front of the pulley.
I've just slackened my cable and it's no where near the mark.
What do you guys suggest?
2Smoke
Thu Mar 26, 2009 9:27 am » Post: #6 » Download Post
How was it running with it set as it was?
CircuitR
Fri Mar 27, 2009 3:58 am » Post: #7 » Download Post
Pretty smoky, I've slackened it right off and I'm about to kick it over again to balance the carbs. I'll see how that is.
At full throttle it sits roughly in the middle of the two marks.
Confused
