Sprocket sizes............
WhiteBaitNZ
Sat Aug 02, 2008 9:16 am » Post: #1 » Download Post
Hey There,
You guys that are racing your NSR's what sized sprockets are you running??
What size is standard??
Sat Aug 02, 2008 11:41 am » Post: #2 » Download Post
That's a bit like asking "what jetting is everyone running?".
For a start, each model has different gearing (both internal and final), so without knowing what NSR you have means the question is unanswerable!
Race gearing depends on the circuit. Basically (very basically) you want to gear top just to hit redline at the end of the longest straight. Of course, if that buggers up too many low speed corners, then you will probably have to sacrifice some high speed RPM and gear a little lower.
Too many variables.
Sat Aug 02, 2008 7:51 pm » Post: #3 » Download Post
You'll struggle to ever get geared right, the problem is really the stock gearbox, massive gaps between gears caused mainly be a low ratio first mean at some point on a lap at just about every track you're lost for a gear.
The solution is an F3 box.
WhiteBaitNZ
Sat Aug 02, 2008 9:15 pm » Post: #4 » Download Post
Sorry for not providing the details before... It's an MC21 and it's running a standard gearset.
I thought it was worth a try! I guess it'll just be a process of elimination.
Do they still sell F3 gearseta or is a case of tracking them down??
fenton
1990 Honda NSR250 MC21
Sat Aug 02, 2008 9:38 pm » Post: #5 » Download Post
found this on jamies site mite be some help
http://www.dreamgate.ne.jp/NSR/technical/mc21sprockets.html
nxrsr20
Re: Sprocket sizes............
Sun Aug 03, 2008 1:04 am » Post: #6 » Download Post
13 tooth front (I think Exclamation )
41 tooth rear
Sun Aug 03, 2008 1:42 am » Post: #7 » Download Post
For fear of repeating myself... again!
Rolling Eyes
Incidentally, NO NSR uses a 13T front sprocket as standard. The link John provided even highlights the standard gearing on an MC21, and it doesn't take Sherlock Holmes to work out the standard final drive gearing for any model if you look at the Online Parts Manual.
Come on guys, as I've said a thousand times over, you really are hard pushed NOT to find something that's covered on the Main Site or discussed/answered in the Forum already.
WhiteBaitNZ
Mon Aug 04, 2008 4:34 am » Post: #8 » Download Post
Hey thansk for that link Fenton! It was a huge help!
I'm gonna go down one at the front and it should be perfect!!!
scottvor
    Send private message View user's profile Send e-mail AIM Address
Mon Aug 04, 2008 9:32 pm » Post: #9 » Download Post
I've run the range of 38-44 on the rear. I run a stock front sprocket.
jkolewski
Tue Aug 05, 2008 1:10 am » Post: #10 » Download Post
15/42 street 16/40,38,36 track
1995 A kit TZ 250
1994 Rothmans NSR 300sp SOLD
