MC16 forks question
Kieran
MC16 forks question
Thu Feb 28, 2008 5:35 am » Post: #1 » Download Post
Helloo All.
What weight fork oil?
Also, when you check fork oil level, do you have the weight on the bike, or do you have it on the stand?
The Chopster
cgallant
2001 Honda RS250
Thu Feb 28, 2008 12:20 pm » Post: #2 » Download Post
Generally when I have checked fork oil/rebuild forks, I tend to do it with the forks off the bike. I have seen people replace springs/shims in their forks with the forks on, but their not replacing fluids, or checking anything with the fluids.
If your going to do it with the forks on the bike, I would probably think you want to suspend the bike from the triple tree so you have no weight on the forks.
Charles Gallant
Kieran
Thu Mar 06, 2008 8:24 am » Post: #3 » Download Post
Any news on the fork oil weight?
The Chopster
Thu Mar 06, 2008 3:58 pm » Post: #4 » Download Post
From the big blue book of Honda words... and the English Workshop Manual once it's finished! Wink
383cc ATF (automatic transmission fluid)
108mm level (measured from the top of the stanchion
0~0.4kg/cm² Air pressure
Canuck13
Sat Mar 08, 2008 8:27 am » Post: #5 » Download Post
hmmmmm does this mean you cant play around with the oil viscosity........
cgallant
2001 Honda RS250
Sat Mar 08, 2008 11:39 am » Post: #6 » Download Post
you can use what ever weight fork oil you feel works best for you, as well as the amount. I think Andy was posting what Honda recommends in the factory manual.
You will find most suspension tuners will use oil weight and amount as a fine tuning of the forks performance.
Charles Gallant
Canuck13
Sat Mar 08, 2008 10:00 pm » Post: #7 » Download Post
Thanks Charles, fwiw i'm running about a 12.5wt (50% 10wt 50%15wt) seems ok so far.
Kieran
Mon Mar 10, 2008 9:30 am » Post: #8 » Download Post
What do you weigh, Canuck13?
The Chopster
Canuck13
Mon Mar 10, 2008 9:43 pm » Post: #9 » Download Post
74 to 78kgs
