Starting then dying...
czsphl
    Send private message View user's profile Yahoo Messenger
Wed May 02, 2007 11:16 am » Post: #1 » Download Post
Guys I really need help on my mc18. Here is what heppened. When I start it at morning it will start without a fuss at one kick.. then as usual.. it will idle a little bit higher and smokes a lot because it will burn any excess oil or fuel.. then before it gets hot.. the top cylinder dies and eventually the bottom will die too.. and sometimes the bottom dies first then the top.. I have new piston rings so I will discount that.. when I pull the plugs out and plug in new sets of plugs it will start ok and I will be able to run it again but the next morning it will happen again. but when I was able to run it and heats up it wont die and runs ok even if I turn it off then run it again its ok.. the only problem is the first start in the morning. I dont thing its the temperature because I live in a tropical country and morning here is like summer in europe.. do anyone has an idea?
Thanks guys
czsphl
Thu May 03, 2007 3:37 am » Post: #2 » Download Post
anyone got idea?
Thu May 03, 2007 4:24 am » Post: #3 » Download Post
Don't leave it ticking over for so long?
Thu May 03, 2007 6:47 am » Post: #4 » Download Post
It's either too rich mixture and or injecting/premixed too much oil if it's really bad or you're just expecting too much if you're leaving it for ages, it is after all a stroker, they don't like steady revs at any level.
I don't leave mine sat there ticking over but it would die inside 5 mins if I did..
czsphl
Thu May 03, 2007 11:47 am » Post: #5 » Download Post
Thanks for the reply guys.. I'll try to lean the mixture and lessent he oil..
pbekkerh
Thu May 03, 2007 12:07 pm » Post: #6 » Download Post
don't just lean and lessen!
CHECK/ADJUST oil mixture and CHECK/ADJUST oil injection
maybe you just have to flip the gas once in while, instead of a slow steady idle
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
