weak NSR250?
PhiLLaY
weak NSR250?
Sat Feb 17, 2007 3:47 pm » Post: #1 » Download Post
Hi guys,
My mc28 seems to be slow compared to my mates rgv vj22 and cbr250rr. my bike is standard except for a short throttle cable. Is this normal? I seem to lose to the cbr in a striaght line drag from 0-100km/h i only manage to creep up when in 3rd. My mate with the rgv (stock) even says the bike is slow compared to the rgv but the power delivery is smooth doesnt feel like there is powerband. My bike has done 22000k no rebuild. Is this normal?
Stock and really slow MC28SE Repsol Rep... =(
fenton
1990 Honda NSR250 MC21
Re: weak NSR250?
Sat Feb 17, 2007 3:54 pm » Post: #2 » Download Post
PhiLLaY wrote:Hi guys,
yep its a 28 Wink
fenton
Sat Feb 17, 2007 3:57 pm » Post: #3 » Download Post
fontyyy steve or andy will be here in a bit they will tell you how to get more from a mc28 mate
Sat Feb 17, 2007 8:56 pm » Post: #4 » Download Post
If the bike is 100% stock then you will struggle to keep up with cyclists. The MC28 is quite heavly restricted. Most of the information you need can be found in the Tuning section of the site.
A quick run down of what you need to do though is.
Wire splice
Derestrict the stock pipes or fit race pipes
Or
HRC card
Wire splice
Race pipes
HRC jet kit
This will see you from around 40hp (stock) to 55hp (option 1) to 60hp (option 2).
I admit I'm not that in the know when it comes to '28 as they are.. lol a bit weak.
I'm sure Fontyyy will put me right if I've gone wrong anywhere (in the post fontyyy not in life thanks).
Sat Feb 17, 2007 9:27 pm » Post: #5 » Download Post
There is no wiresplice to do on the '28 unless you've got an HRC card, it's not restricted as such, it's just rubbish.
Basically the '28 ingition is far is too retarded as std, I've not seen a decent one with the normal card, Matt has made some vaguely impressive (ish, high 50's) figures, I'll bet he still fell asleep road testing it.
Leigh's is particularly poor, even with a '21 flywheel you're right - there is no powerband Laughing
You need an HRC card, a modded airbox and either derestricted stock pipes or fit race pipes, alternatively get used to RGV's whipping your ass.
watfordhorn
1995 Honda NSR250 MC28
Sat Feb 17, 2007 11:17 pm » Post: #6 » Download Post
Watch it !!!
Mine has a HRC card ! Laughing
Sat Feb 17, 2007 11:48 pm » Post: #7 » Download Post
Thats nice Leigh, maybe you should try fitting it at some stage?
PhiLLaY
Sun Feb 18, 2007 1:45 am » Post: #8 » Download Post
Thanks for all the info guys, I know the 28 was restricted but i wasn't expecting to get whooped not by a cbr250rr Crying or Very sad
ok so I have to hunt down a HRC card, some pipes and drill holes in the airbox to fight off the RGVs and lift the front wheel up.
Sun Feb 18, 2007 9:07 am » Post: #9 » Download Post
Himmm, the CBR250 coming past could be rider error.......
rodney007
Sun Feb 18, 2007 11:02 am » Post: #10 » Download Post
rider error?ah... no m8, nice try
um i have a mc28
it goes very fast compared with my cbr250r (mc22 RR engine conversion)
i think a full carb clean should restore lost power,
other than that i dont really know, but yeh cleaning carbs has always restored alot of lost power on my bikes, new plugs, air filter/ fuel filter works nicely also,
mainly carbs,,
i duno but mine pulls up in first gear and u can definatly feel alot of power hit in at 7000-8000 rpm
hope u get it sorted,,Very Happy
Wrench.
Sun Feb 18, 2007 3:58 pm » Post: #11 » Download Post
Put a set of Tyga pipes on there and tune the jetting right, you will be pleasantly impressed!
For a very long time, I ran my '28 with just a set of older JHA's, opened airbox, and Daytona filter. That configuration held me neck-and neck with any CBR or VFR 400.
My guess is that your stock pipes are plugged with soot.
Most would say your mileage is high, but I have seen these engines pull over 50,000km without rebuild. I wouldnt recommend that, though, as those engines ran their entire life in stock, restricted form.
Paul Herr
'88 FZR4/GSXR/YZF Frankenbike
MY BIKE PICS
rodney007
Mon Feb 19, 2007 12:50 am » Post: #12 » Download Post
before you do anything anyone says that requires high amounts of money,
just get the carbs cleaned,
it may fix the powerloss,
PhiLLaY
Mon Feb 19, 2007 11:30 am » Post: #13 » Download Post
alright I will take apart the bike on the weekend, would it be beneficial to take the exhaust apart and clean it if thats even possible? what is required for a carb clean?
Wrench.
Mon Feb 19, 2007 4:32 pm » Post: #14 » Download Post
Take a look at the carbs and see how clean they are, but usually there is no problem unless the bike has been sitting for a long time or if junk from the tank made it past the fuel filter. If the bowls look real clean, I suspect the carbs are just fine.
Take a look at your exhaust valves and see if they move with the bike running. Maybe there is a problem. I would suggest removing the valves from the heads and cleaning the carbon from the valvles and the exhaust ports.
As for cleaning the pipes, I have heard of people hot-tanking them at an engine shop. Baking also works awesome, but makes a smoky mess, so you need good ventilation. If you baked the carbon out of the pipes and cut the restrictors at the inlets, it would most likely make a DRAMATIC difference on your bike with 20,000km.
Paul Herr
MY BIKE PICS
PhiLLaY
Tue Feb 20, 2007 3:00 am » Post: #15 » Download Post
when i purchased by bike from its previous owner, it has been parked in the garage for 6 months but still serviced every 6 months. It had only done 500km in the last 2 years until i got it 4 months ago i have covered 2000km. On some days the bike is fast but usually its smooth I don't think the engine is dying but it should be putting out more power. Is there some spray that I should use?
