Strange starting method!!!
demetris74
Thu Feb 08, 2007 10:25 am » Post: #1 » Download Post
Sorted out the jetting had 140 went up to 150 bike runs clean all the way up with good plug color.
Other problem still remains though.
In order to start the bike i remove the lower cylinder plug and poor some fuel inside. Then the bike starts form first kick. If i switch off the bike it can start again after lets say 10-20 min.
Now if i try to start the bike the next day all the same again.
I've checked the tank breath ok, The carbs are clean ok, i have a strong spark, what is suspect is that the bike doesn't draw enough fuel at kick.
Is there any possibility would be a blocked air solenoids?
The compression feels good, even if i dint make a proper check. And when the bike starts it runs really strong,
I have an MC18 flywheel on the my MC21 does this have any relation due to less advance?
Demetris
Thu Feb 08, 2007 10:48 am » Post: #2 » Download Post
My MC21 was a pig to start from the day I bought it, 12 years ago.
Only since the latest rebuild has it been better, but it's still not a great starter.
Fontyyy on the other hand (as well as some others) can start his by hand!
demetris74
Thu Feb 08, 2007 10:49 am » Post: #3 » Download Post
Strange indeed..
I gues i have to live with this.
Demetris
maxim
Thu Feb 08, 2007 10:53 am » Post: #4 » Download Post
I've had ones that you can start by hand, one 28 I had starting first kick with a tiny bit of choke when it was -10 here one morning!
My current one is complete biatch to start and usually involves rolling down a hill to bump start... I wouldn't think anything is wrong with yours. just make sure you don't use any throttle at all for the first kicks.
beakergixer750cc
Thu Feb 08, 2007 12:59 pm » Post: #5 » Download Post
My 16 with 18 top end starts 1st kick every time Laughing and when its warm by hand 1st time every time Cool
demetris74
Thu Feb 08, 2007 1:08 pm » Post: #6 » Download Post
Spark head range in winter maybe?
beakergixer750cc
Thu Feb 08, 2007 1:14 pm » Post: #7 » Download Post
winter you can say that again!!6 inches of snow outside my doorstep Mad Crying or Very sad
demetris74
Thu Feb 08, 2007 1:52 pm » Post: #8 » Download Post
Gixer
I mean is spark plug heat range has to do with starting problems in winter?
Demetris
beakergixer750cc
Thu Feb 08, 2007 1:53 pm » Post: #9 » Download Post
what starting problems in winter Laughing
Thu Feb 08, 2007 2:04 pm » Post: #10 » Download Post
BR9ECM in top cylinder head, R5300-10 in the (HRC) lower cylinder head... 5 degrees the other afternoon... started! Smile
Before the rebuild, BR9ECM in both cylinders (as specified by Honda). I would strongly recommend against messing with plugs to try and solve a starting issue.
demetris74
Thu Feb 08, 2007 2:45 pm » Post: #11 » Download Post
Good
Thanks Guys
Demetris
beakergixer750cc
Thu Feb 08, 2007 5:39 pm » Post: #12 » Download Post
Hey Demetris,
i could take the plugs out and my bike would still start first kick when cold! Laughing
It doesnt look as nice as yours though Wink
demetris74
Thu Feb 08, 2007 7:44 pm » Post: #13 » Download Post
Thanks Gixer
Will try my best to make it look nice in the inside as well
pbekkerh
Thu Feb 08, 2007 7:55 pm » Post: #14 » Download Post
Both my bikes get a shot of dieselstart if they've been standing more than a month.
If started regularly, they start start ok, but not always at first kick.
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
Thu Feb 08, 2007 11:29 pm » Post: #15 » Download Post
My '18 starts pretty much 2nd or 3rd propper kick if its used every other days or so, If its been stood over a week it normaly takes a few more. Needs a little throttle when hot but starst 1st or 2nd kick
The '21F3 starts pretty much first bump with a bloody great BING!
Edit: tsk, spelling
