New marketplace product suggestion: Rearset plates.
pbekkerh
Sat Apr 29, 2006 9:44 pm » Post: #1 » Download Post
Someone please make some plates with a multitude of threaded holes, enabling us to move the standard footrests back and/or up as wanted.
They would be cheaper, as efficient but maybe not such posers as normal rearsets.
Poul B-H
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
fenton
1990 Honda NSR250 MC21
Sat Apr 29, 2006 10:04 pm » Post: #2 » Download Post
give me some me more detail of what you want and i will see what i can do for you, no promises
nsr.wayne
Sat Apr 29, 2006 10:11 pm » Post: #3 » Download Post
If your going to make some that Andy could sell through the market place I would buy 2 pairs.
pbekkerh
Sat Apr 29, 2006 11:24 pm » Post: #4 » Download Post
it should be a plate that connects to the frame, to the 2 points where the standard footrests connect. The rest of the plate should enable the std. footrests to be moved back and/or up within, lets say 2-3cm back and 3 cm up (or what people want) from standard position, which would give you 6-9 threaded holes.
It should be bent or machined so that the rests wouldn't be moved outwards but only back and up.
The plate should be stiff enough so the rests are stable.
I have seen some plates, some time back, but can't find them again.
they could be bent out of stainless, that would be easy/cheap maybe a little heavy, but they could be straightened easily after e crash or machined out of aluminium, but then would probably have to be replaced after a crash.
A longer gearchange arm should of course also be found/made.
Poul
MC21SE, KISS box
pbekkerh
Sat Apr 29, 2006 11:26 pm » Post: #5 » Download Post
The plates would also be of value to people who contemplate buying an expensive rearset, but don't know how long back and up they want.
they could buy some cheap plates to test the position and then find a suitable rearset.
Poul
MC21SE, KISS box
Sun Apr 30, 2006 3:18 am » Post: #6 » Download Post
Dave Ett is the man for cheap (nasty?) alternatives to rearsets, all you need is a bit of steel (preferably rusty) to move the bottom rear set hole back 3/4" or so and thus the peg up quite a bit, there's only point in doing one side as on the other side the pipe grounds out first. Dave will tell you which side, I believe the right hand side benefits from a slight lift.
TBF just buy some rearsets.
pbekkerh
Mon May 01, 2006 7:06 pm » Post: #7 » Download Post
here is a picture of some plates:
scroll down to Lucas Fodhviler[url]http://www.sayjes.dk/servicep.html [/url]
Poul
MC21SE, KISS box
