Transmission vs. Crank Case Oil
tuanmynsr
    Send private message View user's profile Send e-mail Yahoo Messenger
Tue Mar 28, 2006 4:27 pm » Post: #1 » Download Post
Transmission/gear oil is separate from the Crank case oil, yes? The crank case / bearing gets it's oil from the 2 stroke oil, yes? So, is there always going to be visible signs of oil in the crankcase? I am rebuilding the top end and looking down the crank case from the top, I notice there is a puddle of oil in there more than usual. Is this normal?
Ducati 996
Honda MC28
RS chassis w/ CR80
76 Honda Z50
Tue Mar 28, 2006 6:08 pm » Post: #2 » Download Post
I wouldn't expect to see a "puddle" of oil in the bottom of the cases, but they will most likely be wet... unless you are building it because one side seized through poor lubrication!!
Answer to the other question is yes... 2T lubes the crank bearings, transmission oil/4T engine oil lubes the gearbox.
tuanmynsr
Tue Mar 28, 2006 7:10 pm » Post: #3 » Download Post
Thankx Andy for the response. Do you know if their is any affects if there is oil in there more than usual. Should I try to syphon it out?
Ducati 996
Honda MC28
RS chassis w/ CR80
76 Honda Z50
Binka
Wed Mar 29, 2006 12:09 pm » Post: #4 » Download Post
I'd not worry about it.
It's just the oil from the last and unburnt charge that has collected at the lowest point plus any bleed off from the oil injection system.
If it were an RG500 you would laugh as the infamous dodgy oil check valve issue usually leave the void behind the inner RV covers full of oil and if let stand, the carbs on the lower cylinders end up half full of uninjected oil.....
Just rebuild and fire up.
