H.R.C. Box question.
Chester362
Thu Jan 19, 2006 9:15 pm » Post: #1 » Download Post
Hi all,
I`ve wired up my HRC box & it starts & runs fine.
Went through the motions of testing everything works & found it would stay running with the side stand still down when put into gear.
I`m not too fussed but I`m gonna` be taking it for an M.O.T. test & think it might get picked up on.
I checked all the wiring connections & continuity tested the switch & associated wiring, all seems ok. The side stand light comes on when it`s down also.
Just wondering if someone`s come across this before? Is it normal?
Thanks in advance
Roy.
Thu Jan 19, 2006 10:05 pm » Post: #2 » Download Post
Maybe that's why it says "NOT FOR HIGHWAY USE" on it?! Cool
Chester362
Thu Jan 19, 2006 10:17 pm » Post: #3 » Download Post
Andy wrote:Maybe that's why it says "NOT FOR HIGHWAY USE" on it?! Cool
So that`s what that means. Wink
I`ve not had the bike long & can`t remember if I checked this before I rewired it.
If I remember right it didn`t cut out before fitting the box.
I`m wondering if Japanese regs are the same as here about the function of this switch, can`t see the point of having a wire going to the PGM if it doesn`t do anything.
I guess I`m too lazy to put it back to standard & find out what happens Exclamation
Fri Jan 20, 2006 8:34 am » Post: #4 » Download Post
I took my sidestand switch off when I raced mine, and it hasn't gone back on. Passed the MOT fine...
Chester362
Fri Jan 20, 2006 6:28 pm » Post: #5 » Download Post
Ok, thanks,
I`ll just take it in & keep the bloke talking. Wink
I can rig it up to work if I need to I suppose.
Roy.
BOSOZOKU
Sat Jan 21, 2006 8:02 am » Post: #6 » Download Post
Chester362 wrote:Ok, thanks,
Roy.
I Dont think that the side stand switch is part of the test Question
But if you take it to 'College Motorcycles' in Stockport im sure Eric ( he is a massive Trekkie so you could distract him by mentioning that Wink ) wont be bothered about it as he is pretty lenient on tests.
Bosozoku.
MC21R Repsol replica
SC36 'Fire storm'
RG250 MK3 GAMMA 'WALTER WOLF'
DR350SEV winter hack
Sat Jan 21, 2006 10:29 am » Post: #7 » Download Post
The sidestand switch is not part of the test which is lucky as plenty of bikes haven't got one Idea
BOSOZOKU
Sat Jan 21, 2006 5:12 pm » Post: #8 » Download Post
Just tried mine this morning and it DOES NOT CUT OUT when side stand is down and in gear ?
SC36 'Fire storm'
