**Power value** not working? HELP>>>>
new biker
Guest
Fri Jun 04, 2004 5:56 pm » Post: #1 » Download Post
I have just bought a nsr125r, 1999 foxeyes. Has been told the power value is not working so it won't kick up at 7000rpm... and even the garage cant fix it... is it a comman problem? can anyone help? thanx fei
Sat Jun 05, 2004 12:37 pm » Post: #2 » Download Post
Depends why it's not working. Most likely, with it being a 125, the exhaust valve is totally gummed up with carbon as the previous owner has never cleaned it.
Trouble is, if that has happened, it has probably burned out the motor, or toasted the control module inside the ignition unit.
You need to get yourself a manual and remove the powervalve to check the state of it...
