Fuel tap
kwilling
Fuel tap
Tue Mar 23, 2021 7:50 pm » Post: #1 » Download Post
Mc21. Fuel tap
Mine has started leaking around the plate were it’s riverted it’s a original part , have any of you guys brought a after market from flebay if so are they ok , they look slightly different compared to the OEM one but a OEM is about £100
But a after market one is around £20 thanks guys..
ericandchi
Tue Mar 23, 2021 11:31 pm » Post: #2 » Download Post
Aftermarket one I got was used for 5 minutes. The seals inside swelled from race gas and made it very hard to open/close. Its in a landfill so replace. I was lucky and found an OEM which is working perfect with race gas.
Wed Mar 24, 2021 2:24 pm » Post: #3 » Download Post
16950KV3952 £71.80
https://www.fowlersparts.co.uk/search/part/16950KV3682
behu71
Thu Apr 01, 2021 10:38 am » Post: #4 » Download Post
Hi - got one from Impex japan for around $100 (australian) including shipping... Check japan.webike,,,,,,, It has the long spigot you need for the fuel tap, most have only a short spigot!
kwilling
Sat Apr 03, 2021 8:29 pm » Post: #5 » Download Post
Cheers guys but I managed to fix it ,the rubber seal had given up I ground down the 2 pressed rivets , and drilled through the rivets with 3mm metal bit, opened the back plate and made a new gasket out of metal putty . Then pulled together with small nut and bolt . Worked a treat I’ll try to add some pics
Tadpole
Sat May 08, 2021 9:04 pm » Post: #6 » Download Post
Snap. Had the very same thing happen to me days before a track day.
Coincided with using Esso synergy super unleaded which I hadn't used before. I did the same removed the fave plate and used a plumbers o ring number 125 to replace and shape the o ring. Been on 5 days now and no leaks
Sun May 09, 2021 4:53 pm » Post: #7 » Download Post
Nice to see you back on the forum, Tadpole!
