MC21 reed valve cage query
sami1
Sat Nov 28, 2020 2:55 pm » Post: #1 » Download Post
Hi all,
Having completed a bottom and top end rebuild, I found my bike was smoking considerably more upon start up than it did before the rebuild. Much less smoke once warmed up.
I’ve adjusted the oil pump ( thanks Andy) so that at WOT, the line on the middle of the pulley meets the marker on the pump body. No marks on my carburettor slides for 50% throttle.
Upon removing my carburettor twice, I found about a small teaspoon of oil in the bottom of both reed cages.
Is this amount of oil normal?
My air filter is OEM and seems somewhat oily?
Any info appreciated.
Sat Nov 28, 2020 8:45 pm » Post: #2 » Download Post
It's a tricky one to comment too much on, and I will never comment, or allow comment on anything other than standard setup for reasons I've gone over a number of times. It's something you really need to make your own informed decision on, or entrust to a 2-stroke specialist if you're uncomfortable with fiddling. However, in my personal opinion, there's a large [safe] margin for error in the standard setup to cover a wide range of [Japanese domestic] fuels and operating conditions.
Manufacturer's standard settings are always going to be rich. That means for a 2-stroke the standard oil pump is going to over-oil to some degree, and the jetting/needle is going to be rich... it would be financial suicide to release a 2-stroke with edgy/lean settings.
It's common for the filter to be quite wet and oily, as there's always a lot of "stand off" from the carbs. It's also common to see a little oily residue in around the reeds, but there shouldn't really be much more than just a misting.
Sorry to be so vague, but make of that what you will. Remember though, any deviation from the OEM settings is on your own head! Laughing
Max
Sun Nov 29, 2020 2:24 pm » Post: #3 » Download Post
Also worth mentioning that during reuild you probably used 2T oil to assemble? This may take a little time to clear.
Have you had the engine up to full temp yet?
sami1
Sun Nov 29, 2020 3:37 pm » Post: #4 » Download Post
Hi Max,
Yes the engine has reached full temp several times and I carried out the various heat cycles as per the full engine rebuild section.
I have come down two sizes on the mains and still quite a bit of smoke upon start up. Using rock oil synthesis fully synthetic injector oil.
I guess I’ll just have to do some more mileage and see how things go.
Max
Mon Nov 30, 2020 7:43 am » Post: #5 » Download Post
In that case have you tried a plug chop under load to assess the fueling? It is a bit of a faff to do but it is the best way to see how the engine is burning.
Might be worth posting a video of the exhausts running as well? before and after warm.
Your idea of smokiness could differ from mine for example...in the end I would always point you back towards performing a plug chop though, it is the only safe way to know you are running the bike rich enough.
Good luck
