Exxhaust Seals
tleighbell
Exxhaust Seals
Thu Sep 24, 2020 12:55 pm » Post: #1 » Download Post
Just bought exhaust to cylinder seals Part # 18293 KV3 004 for an MC28 engine. They seem very thick compared to the seals that were on there. they are the same thickness as the flange so i end up with a butt joint and fhe flange does not fit into the opening.
Measurements of the 2 different seals are:
ID OD Thickness
Installed 44.1 mm 55.5 2
18923KV3004 43.5 59.4 6 ( the steel part only, assuming the copper parts will crush flat)
Am I ok with those seals? I have no idea of the ones installed were correct.
Thu Sep 24, 2020 1:35 pm » Post: #2 » Download Post
Are you installing aftermarket or original exhausts? If they are original and you have the oem gaskets then they must be right.
They do crush a certain amount when installed.
Thu Sep 24, 2020 3:34 pm » Post: #3 » Download Post
I just happen to have some here...
Sat Oct 03, 2020 9:35 am » Post: #4 » Download Post
Andy wrote:
You just couldn’t help yourself......
Sat Oct 03, 2020 3:58 pm » Post: #5 » Download Post
Laughing
poosterwyk
Sat Oct 17, 2020 2:23 pm » Post: #6 » Download Post
Hi - I have a 96 MC28 and replaced my exhaust seals using the 18293-KV3-004 seals which fitted perfectly into the cylinder head exhaust flanges.The seals that you currently have appear to be much smaller ( 4mm) ??
I live in Burlington Ontario and you can contact me at 905 920 8473 if you have any further questions
