float problem?
NSR-LOVER
float problem?
Thu Jan 06, 2011 8:00 pm » Post: #1 » Download Post
hi im setting my carbs with hrc bits but i cannot bring the floats to the 13mm measurement!
at tyga website the carbs sit differently as ive seen here so i dont know which way is the right to take the measurement....
http://tyga-performance.com/site/index.php?cPath=369_379
http://nsr250.net/forums/viewtopic.php?t=9052&postdays=0&postorder=asc&highlight=float&start=0
I havent tried tygas way but with the nsr-world way i cant get them below 16mm...
Any syggestions??
cgallant
2001 Honda RS250
Thu Jan 06, 2011 10:51 pm » Post: #2 » Download Post
Honda pretty much matches tyga and the two ways pointed out on the thread linked.
Holding the carbs at 90 degrees and measuring, with adjustments made as needed to the float arm.
if your anot able to get the floats adjusted properly, have you pulled the floats/float valve and checked all is clean/operating properly?
Fri Jan 07, 2011 10:53 am » Post: #3 » Download Post
Also see this thread for some more images.
NSR-LOVER
Mon Jan 10, 2011 4:02 pm » Post: #4 » Download Post
no luck whatever i tried... maybe previous owner has messed them up and bented them.
just to be perfect, i want to buy new floats and needle valves, do you know where i can source them?
i know a place from australia but their prices are too much for me... something logical??
thanks!
Mon Jan 10, 2011 4:53 pm » Post: #5 » Download Post
As shown in this image...
...you need to bend the little tab the spring/needle is attatched to to get the level correct. It doesn't matter what someone else has done before, and even if you get some new ones, you will most likely have to set them.
If you can't figure it out, take it to a (decent) bike shop. Basic fundamentals like float height setting, spark plug gaps, and idle adjustment should be well within your capabilities before you start messing about with things like HRC jet kits! Without a good base setup, it's never going to run right, and you'll just be compounding the issue by adding richer HRC parts!
NSR-LOVER
Mon Jan 10, 2011 5:34 pm » Post: #6 » Download Post
Ive tried everything! it took me 5 minutes to fit needles, tubes, jets and over an hour with a friend trying to set the floats with lots of pictures from the netbook... even without the needle valves the floats are going out nearly 20mm at the 90 degree measurement! when i turn the carb as to level the floats with the floor then they go inside near the 13mm measurement but this is not 90 degree thats why i think maybe they are bented. not the tab all the float!
NSR-LOVER
Mon Jan 10, 2011 5:47 pm » Post: #7 » Download Post
what makes me wonder is why matt is doing it with the carbs 90deg but turned around??
i havent tried his way maybe it could work for me!
Mon Jan 10, 2011 6:07 pm » Post: #8 » Download Post
The picture in my post is the picture from the official Honda NSR250 Workshop Service Manual... I don't know how much clearer it can be... it's even an NSR250 carburettor!
Hold it at 90 degrees to horizontal, so the needle just seats, and then take the measurement.
It is highly possible, although improbable that each side of the float will give a different reading. If that's the case bend each side until they are level, then adjust the overall level by bending the little tab the needle is attached to.
As for "even without the needle valves the floats are going out nearly 20mm at the 90 degree measurement!", this makes absolutely no sense whatsoever! Why on Earth you would try to take any measurement without the needle valve fitted is quite beyond me!
I can't make it any clearer... take the bike to a mechanic!
Mon Jan 10, 2011 6:23 pm » Post: #9 » Download Post
ROTFLMAO
You know what you are don't you Andy? Very Happy
Mon Jan 10, 2011 6:25 pm » Post: #10 » Download Post
Have you put the floats in the wrong way up?
Mon Jan 10, 2011 6:26 pm » Post: #11 » Download Post
Well, someone who shall remain nameless did tell me he thought I was going soft lately, and should get the thread-lock back out a bit more! Laughing
NSR-LOVER
Mon Jan 10, 2011 6:31 pm » Post: #12 » Download Post
hahahahaha.... it seems you dont understand! nevermind!
NSR-LOVER
Mon Jan 10, 2011 6:37 pm » Post: #13 » Download Post
Andy wrote:The picture in my post is the picture from the official Honda NSR250 Workshop Service Manual... I don't know how much clearer it can be... it's even an NSR250 carburettor!
i dont care where the picture is from... i just said that "maybe" with matts way i could be right.
Andy wrote: As for "even without the needle valves the floats are going out nearly 20mm at the 90 degree measurement!", this makes absolutely no sense whatsoever! Why on Earth you would try to take any measurement without the needle valve fitted is quite beyond me!
for research purposes! when you have done everything and it is not right then you mess with other things that maybe are wrong.
mechanics??? no thanks ive had enough from them...
poosterwyk
float problem ?
Wed Aug 05, 2020 12:52 pm » Post: #14 » Download Post
Hi guys - I'm setting my float valve levels on my MC28 and I found the same problem as "NSR lover " - each time I adjusted the metal "tab" on the float I got the same measurement ( 19 - 20mm) no matter which way I bent the "tab".I checked the Tyga procedure and found it basically the same but the floats were in exactly the opposite position to the ones shown in the Honda service manual - the Honda pics show the floats at the top and Tyga show them at the bottom although both are at 90 degrees.I set mine up the Tyga way and was able to get the required 13mm from the carb base, hopefully I have set them correctly ??
Max
Re: float problem ?
Thu Aug 06, 2020 8:05 am » Post: #15 » Download Post
poosterwyk wrote:Hi guys - I'm setting my float valve levels on my MC28 and I found the same problem as "NSR lover " - each time I adjusted the metal "tab" on the float I got the same measurement ( 19 - 20mm) no matter which way I bent the "tab".I checked the Tyga procedure and found it basically the same but the floats were in exactly the opposite position to the ones shown in the Honda service manual - the Honda pics show the floats at the top and Tyga show them at the bottom although both are at 90 degrees.I set mine up the Tyga way and was able to get the required 13mm from the carb base, hopefully I have set them correctly ??
If I read this right you say "the Honda pics show the floats at the top"...the way I read the image posted by Andy above is that the floats dangle below the pivot pin, i.e. the floats are at the bottom.
This makes perfect sense, you want the carbs held precisely at 90 degree and the float will "dangle" using gravity to the setting position...surely if you have the floats facing upwards and the pivot pin at the lowest point the floats could "fall" off centre and give a false reading. Not sure why the Tyga image shows them in an opposite orientation.
Does your bike run OK with the setting you have?
