As stated above. MC28 with NC35 forks and 40mm Brembos. Just wondering if I order the MC28 Hel brake line will they fit. Or has anyone any suggestions. Thanks. _________________ John 3:7
Cant see why the lines wont work, but if my memory serves me right I think the Brembo calipers might have a different thread pitch, so make sure you got the Brembo banjo bolt with the calipers. _________________ Proud Father of , 05 ktm 400exc supermoto 2018 honda crf rx supermoto
Because of the brackets, and because the discs are a different size, the calipers are not mounted in the same position. You'll be lucky if MC28 lines fit. In fact, you'll be lucky if NC35 lines even "fit". _________________ Andy.
Thanks Les. I didnt know about the thread pitch. I was just wondering would there be enough length with the calipers being slightly further away on the brackets.
Lesviffer750 wrote:Cant see why the lines wont work, but if my memory serves me right I think the Brembo calipers might have a different thread pitch, so make sure you got the Brembo banjo bolt with the calipers.
Yes. Nissin Calipers use a M10 × 1.25 Banjo Bolt . . and Brembo use M10 × 1.00 _________________ MC21SP
TDR250
HEL lines are excellent. I bought mine with black covers, to look like the originals _________________ Why do things simply when you can complicate them
