MC18SP R6K dyno after wire splice
seattlensr
Mon Jan 30, 2017 11:33 pm » Post: #1 » Download Post
I have a R6K with a wire splice and it came up with 50hp at the rear wheel. Questions....I have questions.... Smile
1. Is that about what is to be suspected?
2. If I wanted to get some more power but not ruin engine life would pipe be my next purchase? If so what pipes? and then what jets with those pipes should I start with?
3. Is there a airbox mod or anything for these bikes?
The power curve looks almost perfect so the jetting seems to be spot on.
bushman
Tue Jan 31, 2017 5:02 pm » Post: #2 » Download Post
What are the compression readings?
seattlensr
Tue Jan 31, 2017 7:07 pm » Post: #3 » Download Post
bushman wrote:What are the compression readings?
Never checked them. The bike has 3700km on it, starts easy, runs great. I made the assumption compression was good.
What's the proper way to check the compression? I've never done it on this type of motor.
bushman
Wed Feb 01, 2017 3:00 pm » Post: #4 » Download Post
https://www.youtube.com/watch?v=myuzWaXSdw4 ,readings should be around 120/125 psi
