MC21 dry clutch tranny oil
nxrsr20
Sun Jan 20, 2008 5:00 am » Post: #1 » Download Post
Greetings all,
Is there anyway I can check the transmission fluid level in a dry clutch engine? I noticed there is no inspection window or bolt to remove.
So when topping it up do I fill as per the destructions and hope for the best?
TIA
Mekros
Sun Jan 20, 2008 2:16 pm » Post: #2 » Download Post
There's a dip stick.
maxim
Sun Jan 20, 2008 2:19 pm » Post: #3 » Download Post
Which needs to be checked when the bike is upright, not on the sidestand. It's integral to the oil cap, so it's not a long dipstick if you don't know what you're looking for.
NSR300R - Why did i ever have a 250...
Sun Jan 20, 2008 4:19 pm » Post: #4 » Download Post
Diagram available here:
General Maintenance
nxrsr20
Mon Jan 21, 2008 6:07 am » Post: #5 » Download Post
Cheers fellas,
I'll have a look at the bike tonight and see how blonde I am Embarassed
nxrsr20
Mon Jan 21, 2008 10:28 am » Post: #6 » Download Post
ok done......all three engines in the shed have the mini dipstick on them.
The only problem now is that one engine is chockers, need to make sure it's only oil! Rolling Eyes
mhunter1175
Tue Apr 15, 2008 10:31 pm » Post: #7 » Download Post
How mini is mini I think mine is broken, anyone know how much fluid a transmission takes...just had engine rebuilt so I think it is completely dry.
Mike
nxrsr20
Wed Apr 16, 2008 12:13 am » Post: #8 » Download Post
it's probably about 20mm long (just under an inch for you Rolling Eyes ) Click on Andy's link to see what it should look like.
I ended up using close to 700mL of oil and it appeared to be spot-on, that was from a completely dry gearbox.
mhunter1175
Wed Apr 16, 2008 12:33 am » Post: #9 » Download Post
thanks! mine is definitely broken
Mike
nxrsr20
Wed Apr 16, 2008 3:25 am » Post: #10 » Download Post
How far up is the break? You'll be atleast able to measure the high level?
mhunter1175
Wed Apr 16, 2008 3:35 am » Post: #11 » Download Post
there's about half of one of those criscross marks left and thats it...but yes according to the digram I should still be able to tell when its topped off.
Mike
