MC18 revised rear shock linkage plates
howl
Fri Aug 31, 2007 3:31 pm » Post: #1 » Download Post
I have just made a set of revised rear shock linkage plates reproduced from the MC18 HRC Formula 3 from the technical section, and installed them on my MC18. It has raised it up the rear a fair bit and the suspension is somewhat stiffer. I have tried but failed to attach a photo just to check that I have got them on the correct way.I have the long edge with the 70mm centres on the frame link and swing arm with the pointy end of the plate facing down . Please can you tell me if they are wrong .Thanks[/img]
Fri Aug 31, 2007 5:03 pm » Post: #2 » Download Post
Yes, with the F3 linkages mounted on a standard shock the rate is much harder.
howl
Fri Aug 31, 2007 5:45 pm » Post: #3 » Download Post
Thanks for the reply,I've just been out for a ride ,I tweaked the preload on the front to sort of match the rear . It went great ,a bit bumpy on the back roads but was very stable on the local roundabouts ,now I've just got to get used to it before Brands on Wednesday.
howl
Sun Sep 09, 2007 5:30 pm » Post: #4 » Download Post
Just to let you know it handled great at Brands, I would recomend this cheap suspension mod to transform the MC18 as it stiffens the rear and gives you over an inch and a half ground clearance ,just brilliant !
Sun Sep 09, 2007 5:40 pm » Post: #5 » Download Post
It does really help an '18 doesnt it. I made a set up for mine quiet a few years ago and then added the F3 shock with another 14mm of ride it.
When Wayne sat his '18 next to mine he was more than a little shocked how different they looked.
Sun Sep 09, 2007 10:15 pm » Post: #6 » Download Post
Not only does it raise the rear, but it also steepens the front forks giving more responsive steering.
jeff350lc
Mon Sep 10, 2007 12:29 pm » Post: #7 » Download Post
I want to get a couple of plates made up but can't find the drawings. Anyone got a link. I,m sure its just me being a Muppet. Laughing
Mon Sep 10, 2007 1:26 pm » Post: #8 » Download Post
http://tech.nsr-world.com/nsr/mc18/f3-rear-suspension/
MC18-21
Mon Sep 10, 2007 3:26 pm » Post: #9 » Download Post
Uhm, this may seem a daft question to most of you but the HRC F3 plates are good for all models or specifically the MC18's?
Mon Sep 10, 2007 3:54 pm » Post: #10 » Download Post
Only the MC18's. The MC21 and MC28 uses different geometry.
They will possibly work with the MC16 though.
Mon Sep 10, 2007 3:55 pm » Post: #11 » Download Post
They only made them for the '18. I dont think the '21/'28 suffer the same way as a stock '18.
jeff350lc
Mon Sep 10, 2007 7:26 pm » Post: #12 » Download Post
Thanks Andy Very Happy
howl
Sat Sep 15, 2007 6:08 am » Post: #13 » Download Post
Thanks for the replies.Just one more question if I may, would fitting a CBR600 shock to get rebound adjustment be OK now I've fitted the linkage or would it be too stiff ? Cheers
Sat Sep 15, 2007 11:12 am » Post: #14 » Download Post
It all depends how the CBR shock is set up. If the CBR shock is set with a higher preload/weight of spring etc compaired to the NSR's then I would say it will be too stiff with the F3 linkages.
The F3 linkage really does increase the ratio of the stock shock by a huge amount.
howl
Sat Sep 15, 2007 1:45 pm » Post: #15 » Download Post
Thanks ,that's what I thought.I'll leave it as it is as it's rather good anyway.
