 Topic: MC18/NC30 hybrid fork question
Chester362
Chester362 » Fri May 18, 2012 8:17 pm
2Smoke wrote:The Damper rod type stanchions will not work with the cartridges though due to the shuttle in the end being too narrow, so you'll have to use the nc30 stanchions which are AFAIK 9mm shorter than the NSR ones.
Hope this helps.
Are the bump stop/shuttles in the NC30 stanchions the same as the NSR ones? That floating ring thing.
I've built up my '91RS forks with NSR stanchions and would prefer to change to slightly shorter stanchions.
Here's a pic' of the NSR bump stop assembly.
