 Topic: MC18 R2J missfiring
nxrsr20
nxrsr20 » Wed Aug 27, 2008 10:29 am
my own personal paranoia means that I would do a top end rebuild on it before you do anymore to it.....just so you know where it stands and you'll also get to check out the barrel condition. To me, your readin sounds a bit low, I'd try a wet reading and if that is significantly higher, then you know it is worn rings as one of your problems.
