I use Optimax in 2 highly tuned engines and have had no issues at all.
If you mix Optimax with avgas 50:50 you get a slightly better fuel suitable for track bikes - more stability in the burn and will tollerate higher compression ratios.
If you can afford it - use 4 star leaded.
