 Topic: A real formula 3 engine
StephenRC45 » Sat Mar 25, 2006 5:48 pm
Yes it uses a HRC loom but it also uses a HRC PGM with no TPS so its not just a case of running a HRC harness. The HRC loom is also designed to work with the HRC reg rec and pick ups etc.
How did you manage to set your tps up in the end maxim? I did a whole load of runs to find the best with some very interesting results.
