 Topic: RC valve movement..
Andy » Sat Mar 21, 2026 6:19 pm
Enessr wrote:
Yes Andy, the pulleys do indeed move
from hi to low, if I first manually move them with
the ignition off, turn on ignition and both pulleys
Cycle back to low postions.
No, I mean if you turn the ignition on, and disconnect the TPS, do the RC Valve cycle to HI?
If you can only get them to cycle to LO, I expect the PGM needs to be examined.
